Help! Stripped allen nut on front brake rotor
I was in the process of replacing a front brake rotor on my 07 450
and stripped one of the allen bolts that attach the rotor to the wheel.
I ordered new bolts so my problem is getting this stubborn nut off.
Any suggestions greatly appreciated. (wish they would make these
things a little sturdier than soft aluminum):thumbsup:
Use a Dremel with a small cut off wheel to make a little "slot" in the allen head, then use a big flat head screwdriver to back it out.
Exact thing happened to me and it worked like a charm. Just be careful not to cut the rotor.
Good luck :thumbsup:
Also might want to try a little heat, I believe the bolts have lock tight on them.
Did both the cut with a roto zip and a little heat...worked like a champ
thanx for the input guys:ride:
