Pipes for 2001 kdx 220r PC or FMF HELP!
Hi i am getting new pipes for my 2001 kdx 220r but i cant choose between Pro circuit or fmf i know there both good companys
Im choosing between the
Fmf gnarly woodspipe and the powercore 2 silencer beacuse i cant seem to find the rev any where? maybe cuz i live in canada but im not sure
Pro circuit Platinum 2 pipe and the factory 304 silencer
Which should i get?
recommendations please!
I ride mostly trails and sand dunes every once in a while i dont ride track very much but i love to ride em when i can!
So which combination fmf or pc? any suggestions?
FMF Gnarly Rev pipe, only if you cannot grab hold of a Pro Circuit Platinum pipe.
procircuit 2 only way to fly
had both on the hybrids liked the pro circuit way better
Another vote for the PC2 after running a FMF rev. Just works better overall IMHO
so pc it is
Thanks alot guys was gunna go with fmf but i think ill go with pc now
FMF REV. What are you guys doing smoking Crack??!!!!!!lol
Green Hornet
but i do alot of trail riding and isnt the rev for deset n stuff?
Yes. but the 220 already has the low end and you need to boost the mid-top of it to make the whole powerband more rippin'. Jeff Fredette says the Gnarly woods pipe on the 220 doesn't work.
I have the Gnarlyon my KDX. Now, if you have the desire to haul butt on loggin roads and are not so much up for the tight sloppy slippery stuff then dont get the gnarly. It will definitely dissappoint. You will lose a ton of top speed. But, if you do want and like all that the aforementioned then it is not a bad option. With the little extra grunt in the bottom of your gears that it helps provide, you will be happy. The Fatty is not a bad option for what you are looking at either. It will cover the top end of the power band more and allow it to breathe a bit easier at higher speeds. Also giving you a little more on the speedometer. I used to have that on my KDX also. But it did not handle the crashes well at all. A couple minor lay overs and that pipe had a couple serious dents and the weld cracked in the middle of the expansion chamber. The fatty also works well with the Pro Circuit trail silencers.
well i ordered the pc platinum 2 pipe and the factory sound 304 silencer cuz i love bikes LOUD! hope i made the ride choice
Hopefully none of your neighbors join the fight to shutdown the riding areas cuz of loud bikes.
all my neighbors like my bikes :ride: so no worries there
If you like loud bikes, you should have just skipped the silencer and run it without one.
Pugnasty, FMF only sells the Gnarly Rev and Gnarly Woods for KDX's now.
you can actually do that run it with out the silencer? its not bad for it i no u can with 4 strokes but 2's ?
smokers need back pressure to run properly whereas the 4 broke bikes need none. put on a shorty if you want loud but don't ride it out here where the environazi's no doubt are installing solar powered microphones in the forest.:ride:
Oh, I didn't say it was good or bad, you just seem intent on making it loud. Most people don't live in a magical land where people love loud bikes. Most people hate loud bikes, especially people who comparatively have spent a lot more to have a "peace and quiet" home instead of the cost of a pipe and silencer.
haha i like my magical land
  • Similar Content
    • By luke8500
      Hi all,
      I have a 2004 Kawasaki kx250 that died suddenly on me the other day. all i can get it to do is backfire every once in awhile. Tested the resistance and everything of the magneto and stator with a multi-meter and all is good.  Coil is new oem Kawasaki the reeds are brand new vforce and the top end and carb have been completely rebuilt.  key on crank is intact and all the timing marks are lined up. I hooked a timing light to it and spun the motor over really fast and found that it is sparking way to late.  The service manual says that it is supposed to fire 14 degrees before TDC but it is sparking way after TDC.  Im thinking its a fried CDI box since its the only thing i wasnt able to check.  Any help would be appreciated
    • By luke8500
      Hi all,
      I have a 2004 kx 250 2 stroke and it wont start.  it only backfires.  I was out riding it one day and came up to a stop so the bike was just idling and it started to try and die so i revved it up a few times then let it die and now it wont start back up.  It only pops or backfires when you kick it.  Its getting good spark and i just put a brand new plug and coil in it. I took the reeds apart and they look like they're brand new.  It was running great before so i dont know what happened.  Im thinking it could be a fuel problem even tho the plug is a little wet if you take it out after a bunch of kicking.  Any help would be greatly appreciated
    • By Zach121
      Alright, found three bikes all located where i live in Texas. I know they're all very different, but if you could tell me what you think each bike is worth, and which one would be the best deal. Thanks.
      Notes: Both 2 strokes have new top ends. I think the front brake lever is broken on the kawasaki.
      KX250 2002 $800-$1000?
      YZ125 2000 $1250
      KTM 400SX 2002 $1200
    • By Ryan Turner
      So I'm at a bit of a cross roads, I currently own a 06 rm250 and I love it. I also have a 02 kx250 which I'm selling with intent to buy a newer two stroke. I can't afford a newer ktm and the older ones aren't that great and kawasaki never impressed me. so I'm stuck between 06 yz250 and 05 cr250. I've heard the yz and rm after 06 are almost the same bike just the Suzuki handles better and the Yamaha has better suspension. So I'm not sure if I wanna buy carbon copy of my bike with slight differences. That's why I'm interested in a cr250 I heard the 02+ models RC valves are shit garbage but was mostly fixed in the 05-07 models. I ride at a track and at some bogs down the road from me. So from people who have owned both, what would you recommend. I know the cr is known for a hard hitting power band which I enjoy since im an aggressive rider. Should i just see which deal comes my way first.
    • By dirtbikesrule
      If you own a 2 stroke dirtbike,please reply once. Im just wondering how many people on this site have them.
