2004 crf450r modded need jetting help
Hi guys, I just got done putting my 2004 crf450r back together and would like some jetting recommendations. Here's the specs:
2004 Honda crf450r
wiseco 13:1 pro-lite piston
mildly ported head
+1 mm intake and +1 exhaust valves Kibble white stainless with spring kit
Hot cams stage 2 cam
FMF Megabomb header with FMF Factory 4.1 carbon fiber muff
Current jetting: 42 pilot 165 main
needle position I believe 3rd clip position
1 1/2 turn out fuel screw
Fuel: 50/50 mix 114 and 91 octane
I just took it out for a break in run of about 15 laps around a local mx track, took it pretty easy. I didn't feel a bit of hesitation or ping but still would like some advice. I'm heading to the Oregon dunes next week and the bike will definitely not be babied out there, but I also don't want to hurt the motor.
Thanks in advance.
p.s. I'll be riding at sea level next week probably temps in 60 - 75 degree range. The track here in Norcal where I took it out is at about 800ft above sea level and same temps. Thanks
that jetting is fine for a intial run.give it a good evaluation and adress any running issues from there.
Thanks Eddie! Much appreciated
