hick487
alright guys lets see ur dr's! put up some pics!
2,393 posts in this topic
I give up
Dude, I just typed an F'n step-by-step manual on how to upload pics and the damn window on TT closed on me... I'm not doing it again.
Quick version: First order of business is to put your photos on a photo-hosting site, I use Photobucket. Then just copy the IMG or HTML code that is associated with the pic on Photobucket (or whatever), now paste that code in your TT reply. Should work.
If you have a nice camera with great resolution, the file size might be too big. You'll need to "dumb down" your photos by changing the file size to something smaller.
Good luck.
Took this a couple weeks ago. Waiting for the DRz flush tail light to come it for it now.
Mods are: Cogent shock, Racetech emulators in front, RMA shield, some bark busters, Supertrapp pipe, (to try and scare the deer off) DJ jet kit, running lights (so I can see the deer before I hit it..) ProBillet rack and generic top box. Running Maxxis steet biscuits on the hoops.
Some Sunday ride video...
http://www.youtube.com/watch?v=kW1bB9yzhm8
Hey! I have one of those stands too, only mines for the back wheel :ride:
A more recent pic
I like the where the mud spots are....what did you do?.... lol
  • Similar Content
    • By deanmellor
      My top end went on m 98 cr 125, the needle bearing clip came out and broke apart and shrapnel got everywhere and blew it up. I cleaned out the top end and washed out the crank with the bike upside down. the bike starts up great and seems to run fine but im getting a weird di-di-di-di-di-di-di noise coming from the motor. i tried adjust the power valve and tightening everything but the noise is still there. Here is a link to a video where you can hear the sound. It gets louder as rpm's get higher and at really low rpm barely idling it goes away. I am pretty new to bikes and 2 strokes so any help would be appreciated.
      https://youtu.be/msfU8WCXg8E
    • By RidingWithStyle
      In need of Cycra Handguards (probends) for my bike. Need 1 1/8 clamp size for renthal twinwalls. Message me if you have any for sale at a good price!
    • By Markl5557
      Morning ,
        I am looking for recommended radiator guards for my 2017 drz400 I was looking into the devol metal ones . Any one have suggested brands? Replies are always appreciated !
    • By Ted Lukecart
      Parting out a 98 KX250.  NOTE: bike is not complete so if you ask about "price for all" it will be based on each part and only a 10% discount plus freight shipping.
      Parts List:
      2- Engine cases with new bearings installed (right & left) $350
      1- Case gasket set (new) $25
      1- Crank w/rod (new unused) $150
      1- Transmission gear set $100
      1- Set of shift forks $50
      1- Shift drum $25
      1- Kick start input shaft/gear/spring $25
      1- Clutch disk set $75
      1- Clutch basket $50
      1- Clutch pressure plate $25
      1- Clutch lever and input shaft $15
      1- Fly wheel $50
      1- Stator w/wiring $100
      1- Wiring harness $50
      1- Coil w/wire $25
      1- re-plated cylinder (New unused plating)(NO power valve assembly) $350
      1- Top end gasket set (new unopened) $25
      1- power valve assembly $75
      1- Piston/rings/wrist pin (New in box) $85
      1- Cylinder head $50
      1- Kick starter $15
      1- Shifter $115
      1- Clutch cover $25
      1- Power valve cover $15
      1- Fly wheel cover $25
      1- Carburetor (assembled) $100
      1- FMF Gnarly pipe (plated)(no dents) $150
      1- FMF Power Core muffler $75
      1- air box (stock) $50
      2- Radiators w/cap $150
      1- Fuel tank (standard MX size) $100
      2- Forks (stock) $250
      1- Shock w/linkage (stock) $100
      1- Swing arm $75
      1- Frame w/pegs $150
      1- sub-frame $75
      1- Triple clamp $100
      1- Renthal handle bar w/mounts $50
      1- Hand throttle assembly w/cable $50
      1- Skid plate (aluminum)(no dents) $75
      1- Front brake caliper $50
      1- Front brake lever assembly w/hose $25
      1- Rear brake lever $15
      1- Rear brake slave cylinder w/hose $25
      1- Rear brake caliper $50
      1- Clutch lever assembly w/cable $25
      1- Front wheel w/brake disk (no tire or tube) $50
      1- Rear wheel with brake disk (no tire, tube or sprocket) $50
      1- Front fender (new unused black) $25
      1- Seat w/good aftermarket cover (black & green) $25
      All prices include shipping To Washington, Oregon, Idaho, Montana.  Outside the Northwest I will add additional shipping cost based on your address.
      Call or text for pictures
    • By Simon Davis
      So heres the issue, i have replaced the seals multiple times for the water pump however still get a leak out of the weep hole. Over time it goes into the oil side. I think ive found the issue but dont know how to fix it. There is grooves on the ‘water pump shaft’. To which most would say replace it, its not as easy as that, the shaft is directly connected to the crankshaft so my question is, can i fix these grooves without replacing the crankshaft and thus spliting the case?
