scary fast vs. boyesen quickshot
Hey guys, i'm looking into getting an accelerator pump cover, and i was wondering if you guys have had an experience? any info would be great. thanks:ride:
The covers you listed are a waste of money. Instead, a Merge Racing Adjustable leak jet does what those covers do and it enables leak jet adjustment with a screw driver in seconds. Also, get the Merge AP spring. You will never bog again.
yah, a hundred bucks vs. 200. but if it doesn't work the 200 would be more well spent. haha. how hard is this to install? and how often would you be adjusting it?
The ALJ takes 1 minute to put in on a steel framed bike (assuminrg you can twist the carb), longer on an alloy bike if you have to pull the carb. You only adjust if you need to, no more so than if you were to change regular leak jets. On the Merge Racing site, you can view the instructions as a pdf.
