Kick starter 84kx250
Hi my sons old 84 kx250 i have noticed that the kick starter does not pickup tension until at least 1/4 of the way down the kick is this fixable any ideas
the first several teeth on the kickstart gear is worn inside the case,
this is a common problem, remove cover and inspect should be very obvious
good luck:thumbsup:
is the gear easy to replace
cheers
yep its about one of the easiest gear to replace on your bike just pop off the side cover, usually drain tanny fluid first, and wallah, it should be very obvious how it works in there , just pay attention to return spring location spring wind-up, and gear placement sometimes its handy to have a good digi cam available to snap shots with so when you put it back together it makes more sense
