JE Piston
Do the JE High Comp pistons only have one compression ring as compared to the two on the stocker? I want to get a JE, but I'm a little concerned about one less ring. Any thoughts? I have an 07 CRR450.
Your stock piston has only one compression ring just as the J&E piston does.Perhaps you thought of the Yamaha piston which has two compression rings.but in my opinion lasts no longer or contains compression any better.
Thanks for the info. My last bike was a Yamaha; guess I just assumed all bikes had two rings as I have not pulled the CRF apart yet. Thanks for the response though.
Most guys say they run pump gas with the 13.5:1 JE. I plan on using a stage 2 hotcam also. Have you had good luck with pump gas at that compression, or do you run 100 octane or more?
E
I run the piston that you ask about with a oem 02 cam in an 06 and pump preminum works well w/no ping.
With your configuration how would you say it runs compared to a stock '06?
