Power Curve Question
I have a question about the power on my DRZ.
My setup is stock other than the TT FCR39 (jetted as per instructed by Eddie) and a FMF full exhaust (Powerbomb header and Powercore4).
I have power (torque I imagine) down low and power up at the top of the RPM but there is a slight lag in the middle as the bike picks up speed. I am wondering if anyone had a suggestion to improve the midrange.
No I cant loose any more weight.
Thanks in advance.
you need better cams the S?SM cams are for passing emitions
on my SM I have the stock "junk" carb with re-jeting 3x3 and pipe ... whin I added the "E" cams the tork curve smoothed out and became far more fun to ride
the "E" cams I got off Ebay for $100 ... aney more than that your getting ripped off
if your buying new get the hot cams
If its similar to what mine did, It feels like it goes Flat, then picks up correct..I raised the needle 1 notch & that corrected it. Mine was a Tad Lean.
To raise the needle up I move the clip down one notch?
Yep:thumbsup:
