Mods for 06 RM85
A friend's kid has an 06 RM85 and was looking to squeeze out a little more juice out of that motor. Anyone have recommendations for pipe, reeds, porting, etc to increase the output?
Usually go from 47 R sprock to 48 R but ths depends on the track of course,
i like the boyesen reeds in the 85 over the v-force, seems better throttle response, the Pro Circuit pipe is by far the wasy to go all accross the board on the dyno charts the PC is the best for the
the PC pipe and boyesen RAD valve. after that come hit me up for more.
also
Pro circuit triple clamps upper and lower and bar clamp
boyesen alumin ignition cover or SFB racing
renthal rear sprockets or vortex front.
works connection radiator brace
excell or similar rims
rad or talon hubs with buchanon spokes
no-toil air filters
regina ultra light weight chain
HPC high cool radiator
outlaw high pressure radiator cap
mantiou fork cartridges for front forks
racetech valve emulators for front forks
FOX rear shock sold right here on TT
a rekluse auto clutch for woods racing
galfer wave rotors also sold under the MSR brand name
as far as port or polish we had PC do ours,
there is a athena 82cc big bore kit for it ( iwould recommend a kx80 carb for this mod)
there are some other builder secrets to the kx65, but most of these mods should probably be done before any actual motor building like veramic bearings etc.
