clutch problems xr350
i recently pulled the clutch cover off my 83 xr350 to replace the cam chain and when i reassembled i could not get the clutch cable to actually work the clutch its like there is no tension or very little almost like maybe i lost a piece i pulled it back apart to look and didnt find anything wrong or missing throwout bearing and pushrod was where it was supposed to be anybody have any ideas?
I bet the little ball fell out!
Between the pushrod and pressure plate there is a small (3 or 4mm) ball.
If you don't have a repair manual, get one. If you can't get a repair manual I or someone on this site will post or email you the pertinent schematic.
thank you. i figured it was something like that . now i guess i,ll look to see where the 'little ball' ended up! thanks again!
