Hour meter install??
I can't get my Hardline hour meter to get a reading on my '08 CRF250R. I cut away the outer sheating and there are two wires(both coated) that I wrapped the hour meter wire around. Before I go hackin' into my plug wires, anyone outhere with an '08 CRF250R who has one that's working?🙂
I dont have the same brand (cant remember the name) but had the same problem, solved it by moving the connection (loop) down as far as possible on the spark plug boot, it dosent have to be on the wire, in other words the loop can be larger to fit around the boot not the actual wire, hope this helps!
Try hooking it into the black&white wire that comes from your kill switch...
i have a hardline, im on my 3rd one now, first 2 broke...they say they only get 25 failures out of roughly 50k meters sold....so my incident was a real rarity......anyways i just tied my wire to the boot real quick on the back of the truck at a gas station on the way to the track....ha it got loose once but its fine around the boot, i tried higher and i dont get a reading....mines an 06 but the boots are the same as the manual says
Try reading the FAQ at the top of the page. It's all there.
OK, I moved the wire down around the boot. I'll find out if that works tomorrow. Thanks guys!🙂
