EBC MXS Rear Brake Pad Question
I just purchased a set of EBC MXS rear brake pads for my 06 CRF450R. There is a yellow sticker that states not to re-use the shim and insulator. Does this mean no insulator is needed with these pads? It doesn't look like there is enough room to replace and use a new shim and insulator.
I sent EBC an e-mail to their tech support with no response in over a week. They are impossible to get in touch with.
The EBC's are too thick to use the OEM insulators. I hope you have better luck than I did with them. Mine wore out very quickly.
After my latest set of EBC's still on the bike, I will go back to OEM when they are gone. Less braking power and they don't wear too well, as Cam states.
same problem here too. i didnt use the insulators, but i did use the shims again. good luck!!!!
