TTR Wheel Up-size?
Hi!
I have a tall 12 year old that learned to ride on a semi-auto 90 with 12" wheels.
I'm not sure he's ready for a clutch yet, but I need something with larger wheels.
Can you change the wheel size on a semi-autoTTR (similar to the TTR125 and TTR125L)?
Thanks for any insight advice you can provide.
Kevin
IMO, I would find a used TTR125 with big wheels, by the time you spend the money and your time and hassle to make it all work you will have spend nearly as much as a used 125.. Your boy will learn the clutch and be a better rider because of it and the 125 will last for years to come and the 90 might last 1 more year (if that) and you will need to get a 125 anyway...
if you sell the 90, the diff in price will most likely be cheeper than the upgrading the wheels and forks, brake lines, swingarm and the rest of the little things
good luck and let us know what you decide
Yep, the TTR's have an easy easy clutch to learn on. Give him a field and a day and he'll have it down.
