Just ordered PC fatty+FMF silencer,got a question
PC doesn't make the Fatty and FMF discontinued that pipe awhile ago but, In some cases yes you will have to rejet it's more based on altitude and temp than only the pipe and silencer unless it's ported with mods also if your riding in the sand where the motor is always under load as opposed to trail riding at the same elevation. Lot's of good info at bannedcr500riders.com and look in the approved vendors section.
As stated in the post above, I concur. I think that you may have the two backwards, besides the point though.
Rejetting is most likely not going to be necissary. You should be able to throw it and go. Even so, you may have to make some changes. Alot of guys do this sort of mod after having not ridden their bike for a while. With the said the conditions are usually different and therefore the jetting should be different. Just throw it on go ride and see what it works like.
