So this means.....
When your sitting there and you put your bike into gear and it trys to take off it means you need new clutch plates and springs?? Or what exactly do you need to replace?
Make sure your clutch is adjusted properly..
mine pulls a bit with the clutch in. I gotta dig into it and see what's up with it.
It means you need to adjust your clutch.If your bike does'nt when it's cold after first start up it is only dry clutch plates.When you need a clutch the bike will feel like it's stuck between gears and winding out or not fully grabing the gear.
Or a lighter oil. 10-40 is the standard.
