Removal of stock speedo cable and other worthless garbage
The stock computer is pretty worthless for me as I've found it just not that accurate :worthy: so I track mileage and MPH with my Garmin ? . I'm having the computer removed along with all the ancillary garbage like the speedo cable and it appears easy enough just to clip off down by the wheel, but I still don't like the idea of doing that and leaving it "messy" :ride: . I think :D I need a spacer of some sort, and then I can make this clean and pretty just like new. I'm running stock wheels (rims/hubs)...could someone offer some detailed suggestions (e.g. Kawi Part #1234) to swap this out with? Thanks :banghead:
I also wanted to get rid of the stock speedo drive when I installed the Trailtec Vapor ,but found that if you just replace the drive with a spacer you cant use the seal like the other side because the hub is different to a KX hub.
