Oil System DR350 and more
Hello, I really need some help on the oil system for my bike, I just fixed up my bike and wanna make sure the oil system is okay.
The oil I'm planing to use is RacingWay 10W-40MC, and that's the right one.
My bike dosen't have any gauges at all for the oil preasure or whatsoever:cry:
But, this time I'm not gonna have any oil leaks:thumbsup:
But, is there anything I can do to make sure my oil system is okay? - Cause the manual dosen't say much.
And there's this to, when my egine/oil gets hotter, does the oil gett bigger/fatter/exoands or does it get smaler/thinner/lower, someone says that, and others that, but I want the TRUE truth?🙂
By the way, how long, how many kilometer should I drive inn my new piston?:D
Just got a new Head Assy and CamShaft and CamChain to:thumbsup:
Thanks for any answers:ride:
that oil is fine for that bike. oil will thin when hot,but the 40 weight will handle heat fine. as far as oil system being in good shape,i,d remove a valve cover cap and start engine.if you get some splatter of oil coming out,you have oil getting to top of engine. 600-1000 miles(kilos?) will do for a break in period .
