ktm 200 xc vs WR 250
How does the KTM 200 xc compare to a WR 250F in simular conditions?
I know this is like comparing apples to oranges, 2 stk vs 4 stk etc
Yamaha's are more stable at speed, KTM's turn quick, especially if its a 2 stroke compared to a 4. you can get the same power out of the 250f if you worked on the engine a bit. weight difference is around 25-30lbs
the ktm has a 6 speed but its close ratio so probably has the same top speed as the wr, and the tranny will keep the engine in its peak power
here is what ktm says
http://ktmusa.com/200-XC.184.20.html
what do you mean by similar conditions?
