headlight connector
this may sound stupid:bonk: but can someone tell me how they got there connector(the big blue one) apart, im anxious to get my cycra stadium plate on
If you are talking about the piece that holds the headlight bulb in - then all you do is push it in a little and then it will turn. It will only turn one way. You only have to turn it a little and then it will all come apart. Be careful not to let the bulb drop or touch the glass part of the bulb.
I use two small flat-tip screwdrivers to allow the slotted tabs to slide easily over the little nubs.
OK, I looked last night to make sure. I remembered that the first time I took it off I had problems too. There is a tab on the side and I looks like you should push it in toward the connector but it is the opposite. Just put your finger nail under the tab and pull it away from the connector and it should come apart easily.
