DRZ Throttle cable options
Hi,
Eddie, I've heard you say before that its fine to run a 4 stroke without a push cable so i have this to ask.
I'm not happy with the push/pull cables on my 01 DRZ 250, there seems to be too much drag and slop in the throttle tube. So i was thinking of replacing it the whole throttle tube and cable with a quick pull type single cable system. BTW it has a mikuni TM33 pumper if that makes a difference for cable length.
Has anybody done this? (doesn't have to be a DRZ, any 2 cable -1 cable conversion)
Did you have issues with cable length?
was the quick pull system too quick? (ie not progressive enough and you keep winding it out to full revs)
any brand/ model recommendations?
Thanks
Grant
Eddie,
can you advise me on what I'd need to do? I've been told that just removing the return cable will mean that the pull cable can actually twist backwards cos there is no internal "stopper" on the throttle tube.
Should i just look at getting something like a CR/RM throttle tube and housing then a custom cable?
