Rekluse e-axle
Is anyone using the e-axle to change your steering offset? I have a 2006 crf450 and would like the front to turn the tight stuff (mx) a little better. I've got the fork tubes about 5mm above the triple clamp. I like the idea of adjustability and lower cost than replacing the triple clamps.Thanks for any comments.
I have one on my 05 CRF450. Love it. I had 20mm RG3 offset clamps and once I tried the e-axle out with the stock clamps, I ebayed them. I have been running it for 2 full seasons with out issue.
I put it on my 06 450 and noticed an immediate differance in turning,almost had to learn the bike over! worth every penny.
I was thinking about getting one a while back but the axle is cam centric (lobed like an egg) so as you turn the axle to adjust the off set, your forks will raise or lower depending on what off set you choose, be prepared to raise your forks a bit in the clamps to get it fine tuned, not a big deal to some, but others will complain.
