00 xr70 how to change fork oil
I've done lots of work on full size bikes but never one of these
I want to change fork oil
only noticed a little seepage from top of fork by triple clamp -anyone seen that?
the seal area is bone dry
so what is best way to change the oil only?
I don't want to change seals if they aren't leaking
can I pull fork remove cap and springs -do they just come out top? and drain
any need reason to pull bottom bolts
What is good oil wt, amount and air chamber height
thanks for any step by step
Mark
- only noticed a little seepage from top of fork by triple clamp -anyone seen that?
I've never seen that before . Must be the o-ring on the cap ?
- can I pull fork remove cap and springs
Yes
Yes
- any need reason to pull bottom bolts
No need
- What is good oil wt, amount and air chamber height
I forget at this time ... But kinda remember putt'n I think 4 oz's per side in mine ??
The weight of oil depends .. I have 20 w now in mine and it's not enough for me . 🙂
