OEM Muffler removal???
Curious if it is easy to pull off. Does it just come off the midpipe or does it have to be pulled off the header? I have some scratches on the black that look like dung, so I was thinking of taking it down and polishing it until I can get a new Yosh system. Anyone else do this? I know it's a waste of time, but it will be a while before I go with a Yosh setup.
Super easy to remove
Remove the mounting bolt at the midpoint (near the passenger pegs)
Remove the bolt at the clamp (next to the heat shiel) spread and slide the clamp forward onto the header
Remove the rear mounting bolt
Gently work the muffler off.
When re-installing, do not tighten any mounting bolts till they are both in. Tighten, then re-install the clamp.
I took mine off a few months back when I installed the MCCT. It was very easy, and only took a few minutes. Last night, did the same thing to get to the filter screen in the frame, only I removed the header. First time that was done, and again was very easy to separate the two.
