Has my stator already been uprated?
I was doing the valve clearances on my XR650R yesterday and when I took the ignition cover off I noticed that all the poles on the stator were wrapped in wire. The stuff I have read online suggests that only their should be 2 spark coils and 4 generator coils. Im hoping mine is already uprated its an Australian model BTW.
Cheers
Scott
If all your poles are wrapped then yes your probably have a beefy stator...congrats!
is there any way of loading it up to test without risking damage?
Just add another headlight in parallel with the existing one. That or just try a higher wattage bulb. No worries about damaging anything. Just try it. The regulator works by shorting out the coil. Can't get a larger load than that. If it can't handle it, the bulb will just be dim.
