BIB Moose Question
I have installed a new BIB Moose on the front of my XR659R and the bead of the tire is not seated all the way around the wheel. This normally occurs on tires with tubes, but you simply use air presure to pop the bead out. My question is how do you get it to pop out with the BIB Moose??
I wouldn't worry about it. As you ride, I bet the bead works it's way to where it needs to be and since your running a bib moose, it doesn't really matter anyways.
Ok, thanks for the replys. The instruction that came with the BIB Moose are only pictures of putting it in the tire, then the tire on the wheel. No words!
