Brake Pedal Height Adjustment
Has anyone adjusted the height of the brake pedal? I only recently realized how high mine is after comparing it to a DR-Z400. I just want to adjust the non-depressed position so that it is a little bit lower. Right now it's either dead even with the peg or slightly above, I can't recall.
I know there's an adjustment for where the clevis contacts the master cylinder...those nuts on the bolt...but is there a way to adjust the neutral ride height?
Thanks!
you adjust the height using the bolt/nut between the MC and the pedal. You have to remove the clevis from the pedal and turn the nut to shorten the distance to the MC. this will lower your static height.
Don't forget, There is a safety clip on the rear of the brake pedal pivot bolt. Forget to remove that and you are buying a now bolt at a minimum.
