CHP Texas Mini Nationals
The Texas Mini Nationals is coming up quick. This is one you don't want to miss, if you have a pitbike, or even if you don't, you still don't want to miss it. This is one of the largest pitbike races around. It pulls by far the fastest pitbike riders in the country. If you think pitbikes are no big deal, then you haven't seen one of our locals (Andrew Clark), or Oklahoma's Dennis Hotson (88cc world record holder at over 130ft!) riding one. Not to mention CHP's Willy Browning.
www.chpusa.net for more info
www.northtexasmx.com
How much is the entry fee per class, and whats the length limit on a 10 inch bike.
Texas Mini National Rules
12” Pro- Must run a 12” REAR wheel. All bikes must be air cooled four stroke engines with open cradle frame. 14” front wheel (max) is allowed. Must be at least 14 years of age with Parent permission and parent must sign waver for minor.
10” Pro- Must run a 10” REAR wheel. All bikes must be air cooled four stroke engines with open cradle frame. 12” front wheel (max) is allowed. Must be at least 14 years of age with Parent permission and parent must sign waver for minor. There is no wheel base for this class!
12” AM- Must run a 12” REAR wheel. All bikes must be air cooled four stroke engines with open cradle frame. 14” front wheel (max) is allowed. Must be at least 14 years of age with Parent permission and parent must sign waver for minor.
10” AM- Must run a 10” REAR wheel. All bikes must be air cooled four stroke engines with open cradle frame. 12” front wheel (max) is allowed. Must be at least 14 years of age with Parent permission and parent must sign waver for minor. There is no wheel base for this class!
88cc- this is a 10” rear wheel and 12” front wheel. All bikes must be air cooled four stroke engines with open cradle frame. Must be at least 14 years of age with Parent permission and parent must sign waver for minor. You may not run more than 88cc. If you podium your bike WILL be checked. NO CHEATER ENGINES!!!!
12” stock/mod- the following items must remain “BONE STOCK”: Engine head and cylinder (no aluminum heads or cylinder spacers allowed) carburetor (re-jetting is fine, choke must be left on carb) carburetor manifold and engine appearance, frame, forks, swingarm, wheel hubs (wheel size must remain stock), brakes and fuel tank.
Bikes can be modified by changed or adding the following items: upper triple clamps, handlebars, grips, brake cable, kill switch, throttle assy., sprocket, graphics, tires, piston, rings, exhaust system, clutch springs and plate (clutch MUST remain FULLY AUTOMATIC) CDI box, air filter, fork springs, rear shock, chain, footpegs/mount, skidplates, rim and spokes, shifter and brake lever, seat covers and foam, and plastics.
10” stock/mod- the following items must remain “BONE STOCK”: Engine head and cylinder (no aluminum heads or cylinder spacers allowed) carburetor (re-jetting is fine, choke must be left on carb) carburetor manifold and engine appearance, frame, forks, swingarm, wheel hubs (wheel size must remain stock), brakes and fuel tank.
Women’s Pro- May race any bike that adheres to the 12”pro or 10”Pro rules.
Women’s AM- May race and bike that adheres to 12”AM or 10”AM rules. No Sandbagging, if you are a fast chick STEP UP and enter Women’s Pro!
12” Youth- must be 13 and under. Must have a parent or legal guardian present to sign release form. Must run a 12” REAR wheel. All bikes must be air cooled four stroke engines with open cradle frame. 14” front wheel (max) is allowed..
10” Youth- must be 13 and under. Must have a parent or legal guardian present to sign release form. Must run a 10” REAR wheel. All bikes must be air cooled four stroke engines with open cradle frame. 12” front wheel (max) is allowed. There is no wheel base for this class.
Vet- must be 30 years of age by September 6th 2008. May race any bike that adheres to the 10AM and 12 AM rules.
Fat Boy- must be 200LBS+ (without gear). May race any bike that adheres to the 10AM and 12 AM rules.
Have raced it the last few years .Last year was large.Getting the 88 ready and the Pitster ready for the over 30 class.Vince thanks for the help.Ordered Pro Wheels 12/14 from T Bolt USA.The bike is ready.It has always been a fun race.Hope it will be bigger this year
