Steering Head Bearings??
I have a knocking feeling or a slight back and forth movement originating from the top of the front fork area especially felt at speed over a deep whoop section.
I just want to confirm that this is my steering head bearings in need of replacement and not something else?
I've already replaced my front wheel bearings
2006 YZ250
Could be that the bearings are just loose or in need of grease, not necessarly need replacing.
Also check movement of forks below fork tube i.e. the slider. If the slider moves forward and aft independent of the upper fork tubes then fork bushings may need replacing.
