XR250R Fork upgrade - do I need wheels/caliper also?
Hello all,
First post, greetings. I've been reading this site for a short while now and am very impressed with this website.
I am playing around with one of my bikes, a 1988 Honda XR250R, which has the damper rod forks. My seals are shot, and after reading a bit more, the bushings may be shot also (someone mentioned bad bushings usually lead to bad fork seals).
Rather than paying $165.00 for a fork rebuild (quote from a local shop), I"m thinking of upgrading the forks to newer XR250R forks.
I think I read on another site that the newer XR 250R cartridge style forks (1992 model year +) are a direct "drop in" into the stock triple trees on my 1988.
Can anyone confirm this to be true, and if so, do I also need the front wheel/caliper from the cartridge fork equipped bike also?
Thank you for your help.
Forget the XR - let's see a pic of that Mustang.
I don't know the answer to your question but at least you get another bump to the top.
The forks are drop in, but I think the caliper & wheel are different.
You should realize that the used forks you get will also most likely need a rebuild.
I have a set of forks if you need a pair. They are off of my '96 440. I put some inverted ones on there and I do recomend that but if your're set on convential then here you go. pm me.:)
The XR400 uses a larger diameter fork than the XR250s.
From what I've found out is that the '96 and on forks are a direct swap into the last Gen tripple clamps. I don't know why the disc or caliper would be any different though, as long as the disc dia. was the same. I think it was the same on '88-'95 at least.
The rotor diameter is the same but I dont know if the spacers are the same.
