OK, I Give Up..mounting 1 1/8 bars :(
I have Protaper 1 1/8 bars, and do not want to raise them which using the universal adaptor blocks would do. I bought the Protaper "Universal" rubber mounts but the bolts are bigger (M12 instead of M10) and do not want to drill out the cone washers and intrument mounting plate. My bike is an '06 TE610.
Protaper said they have nothing to fit other than than the universal raisng bocks.
Renthal website had nothing on their site for Husky.
Other than the $160 + shipping for the FBF Billet rubber mounts is there anything else?:)
I even went to the Easton site for their new 1 3/8 bars but they have nothing for husky either...
did you give up and just complaining or is this a question:excuseme: :)
call a dealer like motoxotica that knows- but how about the oem clamps off of a 2008????????
or you could get the clamp off a 2002 KTM EXC 250, 400, 450, or 525 which uses an M10 bolt if those bushings from your old one will work with the ktm's clamp- seen in below pic of FBF
Part numbers
6 0912100250 DIN6912-M10X25,10.9,L $1.11 (need 2)
38 59001038200 HANDLEBAR CLAMP D=28MM 2000 $17.18
39 59001039100 HANDLEBAR SUPPORT 28MM SC99 $44.13
5 0015080303 HH COLLAR SCREW M 8X30 WS=10 $1.90 (need 4)
KtmWOrld
I actually have a set of Ferracci adapters I'll sell you cheaper than that. Still in the packaging. Here is a picture if interested.
I believe the after market bar mounts for fatbars for a KX work.
i used the stock 1 1/8 bar clamps and bar off an 08 about for my 07 TE510
fits perfect
mike
I used the Renthal Bar mounts with the Bonz top clamps that also mount the handguards - the only downside is the bolts are not long ebough to use the stock bar riser/spacer.
