ice cube yz276f with 3mm stroke?
is any one runing this set up if so how is it? i think rpm sells it as a yz292 also if you have one how is the power did the crank just drop in or did you have to run double base gaskets or a special one to avoid the piston hitting the head?
Just have the Ice Cube and can't say I'd want any more power. I'd already installed a MegaBomb and Q2
Should drop right in and make a great addition for the money. The difference in stroke is made up by off setting the pin in the crank by 1.5 mm and then adjusting rod length to regain the proper piston to deck clearance. in other words, if you do a stroker crank and lose a rod in the future, you cant just put a standard rod back in the crank....:)
