Biggest Battery
I starting to put my Starter kit in my 560 KTM what is the biggest battery I can put in the Battery box if I going to spend the cash for a battery mite as well get the bad boy Battery as in biggest I can fit in the box.:)
by searching I found that YTZ10S is stock on a 06 625smc- depends on if you used that battery box in the conversion... thats a bigA$$ battery already- especially compared to rfs guys using the upgrade of a ytz7s in their boxes..
if that's the box you used I would think it would be good- I think that's used on most Honda CBR's...
The best replacement battery for the RFS KTM's is the Yuasu YTZ7S. It is just about the same size as the standard battery but has over twice the cold cranking amps.
Here is what I found on Yuasa website
:worthy:
Battery Family: YTZ Factory Activated, Maintenance Free
Battery Type: YTZ7S
Voltage: 12
Capacity (Amp. Hrs.): 6
Dimensions: 4 7/16" x 2 3/4" x 4 1/8"
Weight: 4.6 lbs.
Metric Dimensions: 113mm x 70mm x 105mm
Metric Weight: 2.1 kg
Charging Current (Amps.): 0.6
C.C.A.: 130
Battery Family: Maintenance Free
Battery Type: YTX5L-BS
Voltage: 12
Capacity (Amp. Hrs.): 4
Dimensions: 4.5" x 2.8125" x 4.1875"
Weight: 3.5 lbs.
Metric Dimensions: 114mm x 71mm x 106mm
Metric Weight: 1.6 kg
Charging Current (Amps.): 0.5
C.C.A.: 70
59011055100 Battery Carrier plast.Black 05, is
required if you currently have the 4 series battery.
:D
I have a 2004 400 EXC.
So to use the Yuasa YTZ7S I need to buy KTM part number 59011055100 battery tray.
I think this is the information I was searching for. The 7 is only 1mm bigger all around.
The information is right above your post. Look at the bottom of that post.
