looking for some help with 97 yz 250
hi i am 250 lbs without riding gear!
i am changing out front fork seals,the forks are stock,
what can i do to best set-up for cross country riding,
i am not able to stop with beer and stake.
thanks heavy D.
You can run a higher oil volume that stock to fight bottoming and give it a stiffer stroke. But ultimately to get proper performance you will need stiffer springs for your weight - Race tech has a spring rate generator on their website. I would change out fork and shock oil and put in the proper fork and shock springs for your weight. By doing this you will see a good improvement.
