DRZ400E same valve specs as S?
Hey guys,
I got a 2006 demo E model this spring and it was said to have under 1000kms on it at the time (sprockets looked new). I have put a couple thousand kms on it since and just remembered I should check the valves. I don't have an E model manual, just the S one. Are the valve clearances the same?
Intake: 0.10~0.20mm (0.0039~0.0079 in)
Exhaust: 0.20~0.30mm (0.0079~0.0118 in)
Also, I have never done valves before so any good links on how to's for this type of valves (shim under bucket). I'm pretty handy/mechanical though and should be able to do it once I get a set of feeler guages. I guess I'll need to order the correct shims once I check 'em?
SO far I have the S service manual and this website on how to CHECK the valves:
http://www.pegmonkey.com/howto/valve_adjust/drz400
Thanks in advance for your help.
-Josh
Yes, same specs. Look at FAQ for instructions on valves and other tips on PM and set up.
