valve lash / cam chain question
wondering the correct lash for my engine. it is not stock by any means so im not sure if the "stock " valve lash is reccomended ...what should i set em at ?
also how do you check / adjust the cam chain tention on same engine.
thanks for any info.
mods - 120cc Big Bore Kit ,Heavy Valve Springs,Big Gun Exhaust ,Engines Only Flatslide Carb , head has been ported ,Takegawa Heavy Duty timing chain
Valve lash is .003" In and Ex
Cam chain is spring loaded, loosen adjuster lock nut and set screw.
