DRZ wheels on DR650?
does anybody know if wheels for a DRZ will fit the DR 650?
I see a lot more stuff for the DRZ & wondering if I can swap them out.
Not without a whole lot of modifications. Brake rotors are different size and bolt pattern. Axle sizes are different. Defiantly not a simple swap.
thanks Jeff!
thanks for the carb & vapor & side panels & tail light!
very good instructions with the carb!
I assume your referring to the DRZ400SM. I've read thread somewhere that you could use the DRZ400SM forks thus using its front wheel. But then you would probably be close to the price of a wheel set anyways and still not have a SM rear wheel. I would look for a used set of SM wheels for the DR or just bite the bullet and have your hubs laced. Hope this helped.
