Idle speed yzf 290
What idle speed are you using as a base line for a 290 yzf with hot cam stage two.
1800
2000
2200
any info helps
2200 for an idle? wow thats high. my 250f idled between 1750 and 1850 and my 450 is supposed to idle at 1800, but the emissions control makes it go wacky sometimes(thats going by by real soon)
Your bikes have tach's? mine idles at....... that sounds good 🙂
where can you buy tachs for bikes that aren't too expensive?
trail tech makes a very good product.
it has a thermometer for you coolant, or you can use it for your oil(need to buy a new sending unit)
peak memory, hour meter, miles gone. 2 shift lights, warning lights and tells you your speed as well. I really liked mine. really easy to wire up to a wr too
there only 100 dollars about.
