TE Horn needed
Is anyone not using their TE horn that would like to sell it?
I damaged mine and they are backorder at Halls..
Also looking for one, or a pair of, factory 08 blinkers and factory handguards.
My stock horn crapped out early on. I replaced it with a stebel magnum low frequency. I like it. It's pretty cheap too, like $15. Doesn't fit in original location, but I was able to screw it onto the side of the headlamp in one of the existing holes.
thanks for the insight Chris..
I'll check it out.
I'll check it out.
I see that a lot of places have high prices for the stebel. Here's where I got my TM80 for $13. I haven't tried the high frequency model, I liked the low frequency a lot because it has a pretty cool MOOOOOP sound.
http://www.hornsplusauto.com/
The Magnum (TM80) is plug & play though it is thicker than the OEM so you will have to mount it somewhere under the headlamp etc. The Nautilus requires relays & further wiring, and I don't think it is worth it because the TM80 is quite loud.
