effect of removing shock shims
What will the removal of some rear shock shims do; soften, stiffen or no change, to shock action?
I installed 2000 yr r m 250 brakes wheels and suspension on my chinese dual sport, it rides stiff but it is actually kinda fun to ride now. I did this change on low budget ie atf for shock fluid, cut shock shaft 2 in and retread, cut shock body 2 in (die ground in new spring clip groove) lol, and I need to stay on low budget!
I wonder if it is possible to enclose pic?
Did you use the linkage or is it connnected straight to the swingarm? Removing the larger diam shims will soften it...
I guess you know that at one side of the piston compression shims are located, the other side are rebound shims.
usually you have a number of large shims, then one ore two smaller shims (crossover) and then a tapered stack.
like KTM-Lew said removing the larger diam shims or shims of the tapered stack will soften it, removing crossover shims will stiffen it (low to mid speed compression)
Yes I did use all original suzuki linkages. It was a trick determining location of where to weld on shock linkage frame mount.
Thank you to the people that responded, and I know my weekend will be spent taking apart the shock!
atf in a shock????
man, if i read all this, you're really scaring me... :)
