Help - Can't Seem to Adjust TE 610 Speedo
My 2008 TE 610 speedometer reads too low for the actual speed. Xfool posted excellent instructions for setting-up a new speedometer, but it did not work. The instructions for resetting the oil change indicator worked, but not the speedo.
According to the instructions, I should press & hold the mode button, turn the ignition on, wait for the "ws" to appear in the lower left side of the display, continue holding the mode button, press the "flash to pass" button 5 times, and then release the mode buttom where "0001" should appear. On my bike "End" appears instead.
Did I misinterpret the directions? Any help is appreciated.
On the 08 models the light is not actually flashing until the bike is running. What I had to do was tie the clutch so I could start the bike while holding the mode button then press the flash to pass button 5x.
I have not researched why tis is but it it only on the FI models.
Joe
