What chain are you running?
I recently purchased a RK XW-Ring chain (GB520EXW) for my 06'. When I went to install the chain I noticed the rivets were rubbing the case. I also saw some wear on the case wear the previous chain was touching. Not nearly as much as the RK chain. I purchased it online so now I have to go thru the hassle of returning it. Anyone else have this problem? What is a quality chain that will fit perfectly? Thanks
I went through the same thing recently on my '07 you will need a DID VT 520 x-ring chain. It is the narrow Enduro version. My x-ring standard DID 520 was hitting the cases also and I sent it back to Rocky Mountain ATV for a refund. They later told me they would be carrying the VT but I had already sourced one from Dennis Kirk. No more issues after putting on the VT Enduro chain.
Another option is to get one of the spacers made by fastway. The honda guys are very familiar with this technique.
i'm using a regina oring chain, and i had the same problem....i just reversed the front sproket.
