Help!! Bad Inconcistant Bog
Very strange bog problem. under hard accelerating the bike will just fall on its face (only about 20% of the time). I can always burp the throttle a little and it will pick back up. It does not do this out of every corner but the track I rode last night has two sections that you come out of a corner and into a small step down and then get hard on the throttle, the bike bogs out every time in those sections. It seems to be only in the upper RPM range. Also a couple of times last night the throttle stuck.
Thanks for any help.
Thanks, One thing I forgot to mention. It's a 2005, I rode the bike at least 6 times before the problem started. The last time I rode it before the problem I ran the bike out of gas.
check float bowl for dirt :)
/\ What Dave said /\
