Roll-offs not working properly!
I bought a roll-offs system wich came with the clear lens for my smith piston goggles a while ago but they always stick to the lens wich makes the roll-offs impossible to move!
Is there a way or any product that I should put on the lens to cure the problem?
First, make sure your lens is always dry when you put the film on.
Then you have 2 solutions:
1- they sell a plastic strip that you can stick on the top of the lens that covers the upper part of the film, preventing water from seeping in. I have one and it completely solved the problem.
2- you can always use a fishing cord and make it go around the screws. This will also prevent the film from sticking, but not water from getting behind it.
Smith also makes a special lens that is dimpled, you usually have to order it directly from Smith...
