paddle tire on stock 110?
I've seen a few threads on this but no real answers to the question can a stock klx 110 run a paddle tire? AMS makes a 12" paddle that I hope will fit, I'm just not sure if a stock bike has the huevos to spin it. It's being ridden by a 60 lb 8 year old.
The best bang for your buck to play in the desert will be a smaller c.s. drive sprocket. Try it out as-is, but bring along the smaller sprocket and you can change it for more torque if needed.
That's kind of a heavy mini for the sand, a paddle might help alot, or totally zap your power. Be prepared to give up some speed to get the power back if needed; changing the sprocket and re-setting chain tension is much easier than swapping a tire "in the field". IMO:blah: 🙂:D
