Jetting Specs? JD jet kit - 2003 DRZ400E
2003 E model
Just ordered the JD jet kit
Bike is all stock except for HMF slip on exhaust
Live in North NJ.
I havent done the 3x3 yet, but plan to when the kit comes in.
And advice on Jetting specs? or just follow the recommended specs when i get the kit?
I just re-jetted my 2003 E with a White Brothers R4 slip on and snorkel removed (same as 3x3 just easier/reversible). Everything else is stock. I didn't use a kit I just went with the factory jets and recommended settings I found here while searching.
165 main jet
48 pilot jet
5th clip slot on stock needle (down one notch from stock)
Air/Fuel screw @ 2.5 turns out from close
Works very nicely here at 900ft elevation :)
Good luck!
2003 E model
Live in North NJ.
follow the directions in the kit.
