DRZ High Altitude Jetting-Changing setups
Hi Eddie,
Is there a reasonable way to make it easier to switch back and forth from low to high altitude jetting? Here is my situation:
03 DRZ400S
Stage 1 Dynojet kit; Dyno slide spring, needle with clip on 3rd pos (not 4th like they recommend).
Stock mikuni carb with following setup:
142.5 main
25 pilot
Fuel mix screw 3.5 turns out
3x3 airbox opening
FMF slip on with a 400E headpipe
Stock motor
I mostly ride near the coast, so elevation is 0 to 1000' typically. Once in awhile I ride in the Sierra's at about 7k to 8k feet. At that high altidude I have a problem with low end throttle response, but it seems to run fine above 1/3 throttle.
What is the best approach to solving the low end throttle? Could this be solved via the needle, which is easier to change while on the bike I think, or does the main need changing also?
thanks for your time.
Dave
the slide comes up faster than most bikes on the drz.the main jet is causing your issue.
theres no simple solution.
