cr500 mainjets and crf450 mainjets.....
Yep... The FCRs, PJ carbs and PWK carbs (which many switch to, from the PJ) all use the same family of Keihin Mains. Here's a catalog link, but it is like 30Meg, so only download if you have high-speed internet! Go to page 73:
http://www.sudco.com/vol34/sudco34cat.pdf
Here's the info from the cat:
Applications: CR Special, all FCR’s, FCR-MX, PE, PJ, PWK, PWM.
99101-357-XXX
Size (space) Order No.
#80 019-101
#82 019-102
#85 019-103
#88 019-104
#90 019-105
#92 019-106
#95 019-107
#98 019-108
#100 019-109
#102 019-110
#105 019-111
#108 019-112
#110 019-113
#112 019-114
#115 019-115
#118 019-116
#120 019-117
#122 019-118
#125 019-119
#128 019-120
#130 019-121
#132 019-122
#135 019-123
#138 019-124
#140 019-125
#142 019-126
#145 019-127
#148 019-128
#150 019-129
#152 019-130
#155 019-131
#158 019-132
#160 019-133
#162 019-150
#165 019-134
#168 019-151
#170 019-135
#172 019-152
#175 019-136
#178 019-153
#180 019-137
#182 019-154
#185 019-138
#188 019-155
#190 019-139
#195 019-141
#200 019-143
#205 019-145
#210 019-147
#215 019-149
#220 019-702
#230 019-704
ed man you da man!!!!!!!!!!!.............i have a shitload of jets so now i can tune his bike for him!.......gotta tinker with something becasue mine have not ever really needed any.......going to cpw today too to get him a float bowl gasket........[1 hour away}.........he has a stock carb is it a pj?.....mm?
I answered your PM. Be careful as the idle speed shouldnt' have shot through the moon because of an aftermarket pipe/silencer install. Go through the search for air leaks (and/or fuel deprivation) before making jetting changes, especially if he has dones any other repairs/removals, like carb boots, reed block and its boot, reed block sealing area, dirty carb (jets, float needle/seat, etc), left-side crank seal, etc. Pipe/silencer change won't effect idle speed so drastically, like you have stated. I suspect some other issue and the coincidence is just fogging the mind. Did they guy just perform anything at all on the bike aside from the pipe change?
Stock carb is a PJ 38mm, yes.
Got your next PM. Be careful as a slow bowl gasket leak will NOT cause a higher idle rpm!!! It's just a slow fuel leak and the float height will, or should, remain the same. You're missing something, IMO!!!
he did install a new subframe so he must have an airleak somewhere no doubt in my mind now......i'll keep you updated later-on in the next few days while we tinker...thanks
