Still have a slow bike
I got my x stock from a dealer, used.. upon purchase i re-jetted and cut that air box but my bike still doesnt run properly.. i have fooled around with different pilots, mains, needles, fuel screws and leak jets and i am still at an end...
My buddy just bought a 05x and it freakin hauls ass..pops wheelies in 3rd on 15:44 gearing :D
Now the problem is that my bike runs fine past 1/4 throttle, but before that it still runs like crap... yes it has power, but it wont do a wheelie?????
My bike has no snap like my buddies and he hasnt even cut out his airbox!!???? I cant seem to solve my bog issues and need some help, here are my current specs...
5000k-9000k ft
162 main
45 pilot
fuel screw @ 2 turns
red needle, 3rd position
airbox cut up
pink wire
fmf powercore exhaust
70 leak (back in)
thick ap o-ring
Any ideas????? I want to get the power that i paid for honda :)
Did you mean 45 pilot and 70 leak? I would go with that and DC the O ring mod to see if you can clean it up off idle. Might also go in on your fuel screw a little to see what happens. Another trick you might try is an aftermarket AP cover (www.stealthracingtech.com) and also trying an unoiled airfilter to see what happens.
My buddy just bought a 05x and it freakin hauls ass..pops wheelies in 3rd on 15:44 gearing :worthy:
5000k-9000k ft
162 main
65 leak
airbox cut up
pink wire
70 leak (back in)
thick ap o-ring
Any ideas????? I want to get the power that i paid for honda :D
I just went through the jetting experience myself,.... here is the end result:
Year:2005
Elevation:0-500ft
Temperature Range:40-80F
Smog (AIS):N/A (Canadian Model)
Airbox Modified Top:Yes
Airbox Modified Sides:Yes
Backfire Screen:Stock config.
Air Filter:Stock
Pilot Jet:45 (Stock)
Main Jet:170
Needle:JD Red
Needle Clip Position:4th
Fuel Screw Type:CRF's Only
Fuel Screw Setting: 1 1/8 out
AP Modified:Large o-ring (JD Kit)
Leak Jet:Stock
AP Cover:Stock
Exhaust Type:FMF Powercore 4 w/ powerbomb header
Exhaust Modified:N/A
Pink Wire Modified:no
Stock fuel screw setting is 1 1/4 out , I actually had to 'lean' the pilot circuit slightly to 1 1/8 T.O.
I did the O-ring mod as well the help 'cure the bog' as far as I know your 0 - 1/4 throttle blues can be helped by Fuel screw and pilot jet adjustments.
If you're running the JD Kit ... write to James he may have some advice :)
BTW I'm running the same muffler (+ power bomb header)
Good Luck !
Your main seems lean. Go with a larger main jet and for the he!! of it makes sure you have fresh gas and a clean carb.
A friend of mine had similar issues, it was a sharp dead miss at @ 1/4 throttle. You could ride thru it no problem. We screwed around with the jetting for days and could not change it.
Ended up being a bad spark plug. Swap one from your friends bike and see if it changes it.
BTW at your altitude your main seams fine to me.
+1:thumbsup:
I have the same jetting as you at the same altitude, verified by Eddie's dyno, and it is ferocious.
