CR125 starting issues
I have a 2002 CR125 and when I try to start it will start for a second then die. It does this maybe 10 times before it actually starts. Anything I could do to change this?
im guesing its a carb problem? maybe float bowl height?
do you choke it?
i would pull off the carb and inspect and clean.
what does you plug read?
i would kick it one day 8 times just befopre it starts and pull out the plug and read it then, and then read it after running it 20 min.
