07 CR125 Suspension Settings
Just picked up a new 07 CR125R and in the process of setting it up for off-road racing. I was wondering what suspension settings late model CR125 (05-07) owners are using. What seems strange is that the stock Honda settings and a Motocross Action article settings on the 06 CR125R are so far apart. I'm 165lbs and just trying to get an initial set of settings for the first ride and can then dial it in better. I'm starting with 100mm race sag.
Stock Honda settings for 07 CR125R
fork compression: 6 clicks out
fork rebound: 15 clicks out
shock hi-speed compression: 1 3/8 turns out
shock lo-speed compression: 10 clicks out
shock rebound: 21 clicks out
MXA settings for 06 CR125R
fork compression: 14 clicks out
fork rebound: 10 clicks out
shock hi-speed compression: 2 turns out
shock rebound: 12 clicks out
Man, are these settings far apart!
thanks,
Jeff-
